jackray
Aug 07, 2015Follower
WN3000RPv3 limited
my devices connect to the extender but wont connect to the internet any ideas what to do?
- Aug 11, 2015
Managed to get it working by changing the wireless channel on the router.
nhann
Aug 10, 2015NETGEAR Employee Retired
Hi jackray,
Which router is connected to your WN3000RPv3? Are you able to connect to the internet when using ethernet to your router?
Is your WN3000RPv3 running the latest firmware?
I hope to hear back from you.
NhanN
- g4joeAug 10, 2015Aspirant
Hi,
I have the same problem - just bought the extender and although I can connect to it there is no internet access.
It works fine on the normal wireless access (BT Home hub). Upgraded to the latest Netgear firmware but still no joy.
Very disappointed !
- g4joeAug 11, 2015Aspirant
