Abdel's avatar
Abdel
Follower
Feb 01, 2019
WN3000RPv3 loss of IP address
Hi,
I am using three WN3000RPv3 WiFi Extenders as Access Points connected to sockets in different rooms with Ethernet cables. Each Extender is configured with an unique SSID,  and IP address I use DHCP.
My router is using 172.17.12.x addresses and when I connect to my Extender with my smartphone I got an IP address in that range.
But sometimes, I don't understand why, connection on my smartphone stops and IP address on it changes to 192.168.10.y.
Trouble started since I have added the third Extender in another room.
I wonder if the problem is not coming from router which provides IP addesses to all Extenders, or if there is a limitation of Extender number plugged on the same Ethernet network ?!?
Thanks for your help :)
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Abdel,
    You can try setting up IP address reservations on your extenders to keep the IP's stable
    ~Christian
