grahamholloway
Jan 03, 2019Aspirant
WN3000RPv3. No Client LED and continually beeps
The extender has worked for some time but recently it stopped working. The Client Link LED went out and the unit simply beeps every few minutes. I've switched off and rebooted everything on my network but the extender shows no sign of working other than all green LEDs apart from the Client Link. Should I go through the NEW EXTENDER SETUP process (no WPS button on the router)?
The client link led just means that no clients are currently connected to the extender.
The beeping is another matter - I am not seeing anything in manual (or with google) about that. Maybe DexterJB or Christian_R can clarify.
There's no harm in resetting the extender, and you can set it up without WPS. After the reset you join the NETGEAR_EXT network and then browse to www.mywifiext.net.
- grahamhollowayAspirant
I understand the function of the Client LED. But the lack of the client connection, a TV 15 feet away is difficult to understand. A search for devices to connect to the TV only showed neighbour's computers (secure, of course). Yes, I can find nothing regarding the beeping either. However, I had to shut down the power to my house in order to install a new circuit breaker. While the power was off, I heard the extender beep (battery inside?). On restoring power to the house about 90 minutes later, the extender decided to work correctly and has been working for several hours. But it still beeps every couple of hours or so. Is it requesting a new (support) battery?
- Christian_RNETGEAR Employee Retired
Hello grahamholloway,
The beeping sound from the extender definitely isn't normal. Please send me a message with your contact info/serial number and I will forward it to the necessary department for further assistance.
~Christian
