Wrefx
Jan 10, 2018Aspirant
WN3000RPv3 Urgent Firmware Update Bug
Was already using firmware V1.0.2.50, says V1.0.2.52 is available, downloaded V1.0.2.52 img, hardwired update, and your V1.0.2.52 is bugged and thinks that it’s V1.0.2.50 still... Around in catch 2...
- Jan 16, 2018
Finally! Just updated to the new firmware version 1.0.2.52.
Download WN3000RPv3-V1.0.2.52.zip.
Extract WN3000RPv3-V1.0.2.52.img, 3670149 bytes, January 12, 2018, hash:
CRC32: F684FE99
MD5: CEEDE4C962EF78DFC1C8D33D6BD28D5E
SHA-1: 9A7985B7F276B2C8883B259EC0774676EE70F12B
SHA-256: 2B11A25CD153BE1214E4849649577A8A6281B66E518F4F47E492B4F550AA7362Log in WN3000RPv3, Firmware Update and Upload Update File WN3000RPv3-V1.0.2.52.img.
Remember Known Issues & Bugs:
"While manually updating the firmware, will show wrong version to be V1.0.2.54. Actual function and version is V1.0.2.52."That's all
Best regards
Lorenzo Speronello
Wrefx
I don’t mean to sound facetious but maybe I expect more from a multi billion dollar top 500 IT company, joking aside I can see the firmware script is new, but you might wanna change the firmware identity within the .img, delete a 0 add a 2...simples...
Our security is in your hands...omg?
A few words spring to mind...’sandbox, alpha tested, Q & A’...
/loop
/loop
JimK01
Jan 10, 2018Initiate
Exact same rediculous problem I'm having. Download the xxxx.52 zip file, upzip and see the xxxx.52.img file. Connect ethernet to N300, bring up GUI, go to update, browse to xxxx.52.img file, hit 'GO!!!!' - boom "Sorry Jack! The upgrade version is the same as what's currently running xxx.50. Jokes on you Pal!!"
Come on Netgear - get this fixed!
