DirkTr
Dec 21, 2017Follower
WN3000RPv3 Username login failure after firmware update
I use two Wifi Range Ext as Access points on my network. They each have their own Static IP. It was working fine, and I saw there is a firmware update (V.xxx.50 I think) after the update, routers...
Morpheo
Dec 25, 2017Initiate
Same issue after last upgrade, i'm unable to access with user "admin" and password set.
The error was "user name not recognised".
I've tryed with the username "administrator" and the error change in password is invalid.
At this time the extender work fine but i'm unable to access it.
Anyone know a solution different to reset the range extender??
thanks
