DirkTr
Dec 21, 2017Follower
WN3000RPv3 Username login failure after firmware update
I use two Wifi Range Ext as Access points on my network. They each have their own Static IP. It was working fine, and I saw there is a firmware update (V.xxx.50 I think) after the update, routers...
unhappyfirmware
Dec 29, 2017Initiate
Same problem here with a WN3000RPV3
Looks like this firmware has been released without quality assurance test.
ybr
Dec 31, 2017Initiate
I have the same problem today:
- Connected to WN3000RPv3 – N300 WiFi Range Extender using "admin" username.
- Upgrade firmware to a version ending with ".50".
- The extender is working correctly, but I am not able to access it anymore: error message "invalid username" when trying to log in as admin (I am 100% sure that the username and password are correctly entered).
I unplugged and replugged the extender, but did not reset the factory settings.
Any idea?
Thanks!
