Tomoulay's avatar
Tomoulay
Wn3100rp connexion problem
Hi helpers,
I've been using this WP3100RP during a couple of years without having any problem.
Since a month now, I can't connect any device on the extender. It keeps asking me my password and refuses me to connect.
I can see every time I try to connect on the extender, a small red light appears on the bottom left.
Do you guys have any idea why it doesn't work anymore ? Have tried to reboot everything but it seems to not accept anything.
Thank you for you help,
Thomas.
  • Hello Tomoulay
    Try a factory reset by holding the reset button for 10 seconds then try to setup the extender again.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Tomoulay
    DarrenM
    • Tomoulay's avatar
      Tomoulay
      Hi Darren,
      After 2 reset tries, it now seems to work correctly again.
      I just can't explain why it stopped connecting me for no reason.
      Thanks a lot :)
