log-out
Jul 29, 2015Aspirant
WN3100RP error disabling SSID broadcasting
Hi all, I've recently purchased a WN3100RP and it works fine.. I want to disabling SSID broadcasting, but then I can't connect to it with my laptop (win 8.1). If I activate SSID broadcasting, I conne...
nhann
Jul 30, 2015NETGEAR Employee Retired
Hi log-out,
In order to connect to a disabled SSID, you will need to manually create a network profile. Listed below are instructions from http://kb.netgear.com/app/answers/detail/a_id/22144
1. On the Desktop screen, right-click the Wireless Icon located on the lower right hand corner of the screen, and select Open Network and Sharing Center
2. Select on Set up a new connection or network and then click on Next
3. Select on Manually connect to a wireless network and then click on Next
4. Manually enter the required credentials for the wireless network you are trying to add, then click on Next
5. You will get a confirmation that the profile is successfully added
Let us know if you need further assistance.
NhanN
log-out
Jul 30, 2015Aspirant
Hi nhann,
I've created manually the profile, but my laptop says that it can't connect the the network. If I enable againt the SSID broadcasting, it connects successfully.
- Babylon5Jul 30, 2015NETGEAR Employee RetiredThere are some client devices and operating systems which don’t work well with disabled SSID beacons.
