log-out
Jul 29, 2015Aspirant
WN3100RP error disabling SSID broadcasting
Hi all, I've recently purchased a WN3100RP and it works fine.. I want to disabling SSID broadcasting, but then I can't connect to it with my laptop (win 8.1). If I activate SSID broadcasting, I conne...
log-out
Jul 30, 2015Aspirant
Hi nhann,
I've created manually the profile, but my laptop says that it can't connect the the network. If I enable againt the SSID broadcasting, it connects successfully.
Babylon5
Jul 30, 2015NETGEAR Employee Retired
There are some client devices and operating systems which don’t work well with disabled SSID beacons.
