RugbyRene
Apr 26, 2013Aspirant
WN3500Rp channel designation
Hi again, Have another quick question regarding the WM3500RP. I noticed via iSSIDer that the 2.4 and 2.4EXT signals sit n the same channel (same with the 5G and 5GEXT). Is this affecting the ov...
charm
Apr 26, 2013Novice
Your connection is way best on channels 1,6 and 11..But you have to set each to the same channel eg: 2.4 on only in ch6.
You can actually try to download an app named WIFIANALIZER where you can see different networks running in a channel. In a way, you will be able to know which among the 3 suggested channels have lesser network running in, be in that channel and there you can have no interference.
