chicago29
Mar 17, 2014Aspirant
WN3500RP No Ability to Stream Video/Audio
Hello, I have a WN3500RP set up to extend my wireless network. I am extending off of a Netgear R6300 router and am using the FastLane technology. The primary router and WN3500RP connect via 5 GH...
chicago29
I am using Firmware V1.0.0.20_1.0.60
It is reassuring to know that it at least works for others, but I'd really appreciate some advice on what I can check either on the WN3500RP or the primary N6300 router. It seems something is going awry since I am clearly able to pull a decent signal and bandwidth doesn't seem to be the culprit.
