chicago29
Mar 17, 2014Aspirant
WN3500RP No Ability to Stream Video/Audio
Hello, I have a WN3500RP set up to extend my wireless network. I am extending off of a Netgear R6300 router and am using the FastLane technology. The primary router and WN3500RP connect via 5 GH...
WizardJ
Mar 17, 2014Luminary
What I did do when I first go the D6300 was to uncheck Disable IGMP Proxying under Advanced -> Setup -> WAN Setup as I know some devices require multicast to work. I don't think that should be the case with simple stuff like YouTube though... But you could give it a try.
Have you spoken to Netgear Support?
