chicago29
Mar 17, 2014Aspirant
WN3500RP No Ability to Stream Video/Audio
Hello, I have a WN3500RP set up to extend my wireless network. I am extending off of a Netgear R6300 router and am using the FastLane technology. The primary router and WN3500RP connect via 5 GH...
alpharettark
May 07, 2014Aspirant
FWIW my issue seems to be related to how the 5.4 connection works between the WN3500RP and my R6200v2 router. I turned off Fastlane and video worked fine on 2.4Gbut not 5.4G. For grins I turned back on Fastlane and connected to router with 2.4 and to TV with 5.4. So the issue seems to be the 5.4 connection between extender and router. I even experimented changing 5.4 channel to no avail. Since my laptop does not have 5.4 I would really like to configure the way it doesn't work. Suggestions appreciated.
