Analog6
Mar 14, 2014Aspirant
WN3500RP not lighting up, can't configure
I have purchased this thing and when I plug it in, the power light goes green but no other lights come on. I have it mid way between the computer and the WiFi base station, in plain sight of both. ...
jmizoguchi
Mar 16, 2014Virtuoso
Go to http://support.netgear.com and download the manual
You will find the instruction if setting up the extender ,
Also suggest to try in the house .
Reminder that you ca NOT place extender when your existing wifi device is weak. It needs to overlap the main signals so extender may not be your best shot
Try moving router from existing location to windows facing towards the coverage you need
