ciub
Apr 24, 2014Aspirant
WN3500RP with Chromecast in a hotel room
hi guys I bought the WN3500RP to bypass the login issue with chrome cast, using the device as a router. the problem is, I haven't figure out how. i was unable to set up connection on 5Ghz (not...
schumaku
May 02, 2014Guru - Experienced User
How comes? For example the NETGEAR Trek Travel Router (PR2000) can be used to "hide" multiple computers and portable devices behind one MAC address - sign-on from any system with a browser to deal with the portal sign-on is sufficient for all.
jmizoguchi wrote: Again if hotel uses portal to access it then nothing will work
While testing the PR2000, we had no issues using Multicast based applications on the WLAN/LAN side of the PR2000 in travel router mode.
Of course, hotel portal and Internet connections might prohibit using Multicast in a reasonable way - it's either blocked, or will be distributed all over on most non-managed switch environments and WLAN AP.
