vizakenjack
Jan 15, 2015Aspirant
WN604 - can't access router settings
I can't access routerlogin.net interface on WN604 through wi-fi.
I have a mac pc.
I guess I'd connect my pc via ethernet cable, but I'd need an adapter for that... Besides, I really prefer wi-fi...
So, I tried to connect to the router WN604 through another modem/router - DGND3700, it got connected to the router WN604 successfully. I connected WN604 to DGND3700's cable/fiber rj45 jack. I was able to access DGND3700's settings, but how do I access WN604's settings?
Also, DGND3700 gives me ip and router ip address within 192.168.0.* domain, whereas WN604 allocates ip address (DHCP) within 10.144.54.1/52.
I tried to manually set up an ip within 10.144.54.* range, and set router's ip to 10.144.54.1, but it didn't work :(
Any clues?
I have a mac pc.
Any clues?
- vizakenjackAspirantalright, nevermind, turns out I need to set router's ip to 192.168.0.1
and my pc's ip to 192.168.0.210
But then, I won't be able to have access to the internet, only to router.
Anyway, how do I access WN604's router settings (192.168.0.100) while being connected to DGND3700's wi-fi, which in turn is connected to WN604 via ethernet cable. - Babylon5NETGEAR Employee RetiredYour DGND3700 is your network’s DHCP server, so in the WN604 at the IP Settings page select the ‘DHCP Client’ option. The WN604 will then be allocated an IP address from the DGND3700. When this is done I suggest that you log in to the DGND3700 and use the Address Reservation option to reserve the IP address allocated to the WN604, that way it should always receive the same IP address. You would then access the WN604 settings at that IP address e.g. http://192.168.0.13
