cmd_nyc
Mar 23, 2015Novice
WN604 can't login to setup configuration window
Hi, My WN604 was working fine until recently. We moved, and now I'm trying to create a wireless access point at our new place. After having trouble configuring the unit, I ended up doing a hard r...
cmd_nyc
Mar 24, 2015Novice
Thanks so much! After doing your sequence, then doing another regular 5 second reset, I'm able to log back in.
But I am having trouble with the IP settings of the unit and I can really use some assistance. I'm able to create a wireless network but I don't have an IP. I'm sure I'm not configuring this correctly, and after the reboot I ran into the same problem I just had before. FYI What I'm doing with the Netgear is creating an access point at one end of my space which is too far from the Asus for good wireless connectivity.
My setup includes a TWC modem in bridge mode patched to my Asus router. Then a cable is going into my Mac Pro, which has 2 ethernet ports. The Netgear WAP is patched into the second ethernet port of the Mac. I have a static IP from TWC and I use the Asus to distribute IP addresses to my various computers starting from 192.168.1.100 and go up from there. My Asus is 192.168.1.1.
I guess I'm not sure whether to use 'DHCP' or to enter the IP settings manually. So far I'm not able to get either to work. When I enable DHCP I get an error 'No response from DHCP server'. When I try without DHCP here's the settings I'm using:
IP 192.168.1.111
Subnet 255.255.255.0
Default Gateway 192.168.1.1
DNS are TWC settings
Any help is greatly appreciated!
IP 192.168.1.111
