cmd_nyc
Mar 23, 2015Novice
WN604 can't login to setup configuration window
Hi, My WN604 was working fine until recently. We moved, and now I'm trying to create a wireless access point at our new place. After having trouble configuring the unit, I ended up doing a hard r...
Nhellie
Mar 24, 2015Virtuoso
You will have to set an IP address on the AP that is on the same range as your DHCP server,
see page 16
http://www.downloads.netgear.com/files/GDC/WN604/WN604_UM_5June2014.pdf
once done, you will need to connect the AP to your router/DHCP server so that the AP will be part of your network.
see page 16
