LRFOWLER
Jul 06, 2011Tutor
WN802T access point to N300 Router
So...we have an N300 router and a WN802T access point outputting wireless to our wireless pc..approximately 60 yards away.... I don't understand the use of an access point... Can I connect the acce...
jmizoguchi
Jul 07, 2011Virtuoso
first unless you have clean line a sight 60yd/180ft will be duarable but you will have poor connection
you will need main router output more more will be better.
you need to survey with laptop and if you get poor signal then expect same results with AP as well so you will find out if possible to place where you want
http://www.metageek.net/products/inssider/
use this tool and understand surrounding.
also http://www.engeniustech.com/ these guys has more option for you. stronger router than most consumer unit
