mahesham22
Jan 13, 2011Aspirant
WNAP102 and Blackberry Bold 9700 connection loses
Hi we are using Netgear WNAP210 as an access point. It works fine with all the devices except blackberry phones. I tried 3 different handsets of blackberry 9700 but with no luck. Here is the Pro...
Satras
Jul 20, 2011Aspirant
I had the same problem and couldn't get it to work.
I upgeaded and downgraded the firmware bt nothing helped. Then i started playing around in the WIFI menu and finally got it working. :D
Firmware: WNAP210_2.0.12
Thats just my settings, but non of them really matter as I found. Some people said that setting the Channel to fixed 6 would help.. but not for me.
The only thing which worked for me was entering the QoS Menu and to disable WMM Powersave.
"Enable Wi-Fi Multimedia (WMM)" was still on.
Hope that helps.
Wireless Mode:2.4GHz Band: 11ng
Turn Radio On: yes
Wireless Network Name (SSID): MYSSID
Broadcast Wireless Network Name (SSID): Yes
Channel / Frequency: Auto
MCS Index / Data Rate: Best
Channel Width: Dynamic 20/40 MHz
Guard Interval: Auto
Output Power: Full
Hope that helps.
