aelorenzo's avatar
aelorenzo
WNCE2001 & Appletalk
Hi all members,
Is it possible to use the WNCE2001 wireless bridge become an old Laserwriter wireless? It doesn't hae TCP/IP capabilities, just appletalk. With wired ethernet connections and any router it works. But it is impossible to make it work over wireless.
I am trying to do it without success.
Thank you in advance,
  • I don't think it will support appletalk. that is some old protocol that you don't see much
  • OK, Appletalk is a bit old, but it is just and option in the firmware compilation and programmers work. I mean, with no effort you could support this protocol. It is just a protocol.
    Why is it 'erased' from the world?
    Thousands of printers (also industrial ones) are based on this protocol!!!!
    Netgear was one of the few router brands which supported this protocol five or six years ago.
    It is a shame. Everything is too modern.... Appletalk was a good protocol.
