gazurtoids's avatar
gazurtoids
WNCE2001 browser?
Condsidering getting one of these to connect to a blu ray player...
My question is can you browse the web fully when connected ie through a browser or does it only run apps like netflix etc?
  • well it turned out i did not need the computer. i found the instructions thru the links you provided even though it took a bit to get there kept getting not found messages but i got the instructions and all i needed to do was reset it then push the wps on the netgear box and then the wps button on my modem and then wait for a steady light. after a few minutes my player said it was connected and it started to work. but i may have they did have those instructions in there as well, but those were not a clear as i thought they should be. but thanks a bunch for the help. it now works pretty good. i get a bunch of waiting for the programs to load but that may be another issue to work out. thanks much for the help. bp
