mefam
Jul 26, 2014Novice
WND3400 giving 192.168.2.x IP range
I have a WND3400 wireless router which was working fine until today. The router is giving a 192.168.2.x ip range which shows up as a Belkin router and server so anything connected to the router can't ...
fordem
Jul 27, 2014Mentor
No Netgear product that I am aware of uses the 192.168.2.x network range as it's default, you'll get either 192.168.0.x or 192.168.1.x - if you've hard reset the router these are the ranges you can expect to see.
You say the router shows up as a Belkin. what is the possibility that you are connected to the wrong router?
Disconnect everything from the router and connect your computer to the router with an Ethernet cable - what happens now?
