Lanopy
Aug 07, 2011Follower
WNDAP350 - deauthenticated due to local deauth request
I have a WNDAP350 AP configed with WPA2-PSK. I am averaging about 40 clients in a high usage environment and and am experiencing random disconnects. I have both radios configured and the N network seems to remain stable. The 2.4 however will randomly disconnect users. The messages I am getting in the logs is "deauthenticated due to local deauth request. I have scanned for channel congestion etc and am having no luck isolating the issue. Any ideas on what I can look at to stabilize this?
- grehundAspirantI'm seeing the same log entries on a client's WNDAP350. I have updated to the latest firmware 2.0.27, and disabled WMM Powersave, as suggested by some other forum users. Neither of these changes have resolved the issue.
My client would be lucky to have 5 simultaneous wireless users, yet we experience the same issues as you.
I have tried changing to just 802.11a, changing to WPA1, even Open, the issue still prevails. :-(
If you get this resolved, please post back. I will do the same. - RandolphBellAspirantThis is clearly a memory leak in the current firmware. No matter what setting you use if you are streaming a considerable amount of bandwidth the system will eventually provide the following error messages
Sep 30 19:53:11 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: disassociated
Sep 30 19:53:12 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: associated
Sep 30 19:53:15 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: deauthenticated due to local deauth request
Sep 30 19:53:15 hostapd: wifi0vap0: STA bc:c6:db:1b:26:xx IEEE 802.11: disassociated
I've modified a number of settings to provide a somewhat reasonable configuration. I say somewhat in that I'm basing "working" on streaming an HD Netflix video and despite encountering this error message repeatedly the buffer in Netflix is able to mask the error. The configuration I settled on is
as follows
Channel / Freequency - Auto
MCS Index / Data Rate - Best
Channel Width - 40mhz
Guard Interval - long 800ns
Output Power - Full
I challenge Netgear to respond to or resolve this issue.
-Randy
