Geforce's avatar
Geforce
Novice
May 09, 2013
WNDAP350 & 2 x ANT2407
Hi,
I've set up and purchased 1 x WNDAP350 and 2 x ANT2407 Antenna's but with poor results it seems.
I've enabled external antennas in the 2.4Ghz range, but it doesn't seem to make an awful lot of difference compared to the internal 5Ghz antenna.
At the moment, I'm sat maybe 2 feet from the WNDAP350 and 2 feet also from a standard ISP router and the standard ISP router says ~93% on my wifi scanning tool, but the WNDAP350 is sat at around ~86% on the 2.4Ghz Anntenas but ~90% on the 5Ghz antenna?
If I walk down the office approx 25 feet away with no obstructions, I get:
Standard ISP router ~70%
2.4Ghz Antenna ~65%
5Ghz Antenna ~68%
If I go outside, which is 20ft down and 30ft across the car park, I get:
Standard ISP router ~21%
2.4Ghz Antenna ~16% :confused::confused:
5Ghz Antenna ~21%
To me it looks like the antennas are not functioning correctly - or I've not set them up properly. Any ideas?
  • jmizoguchi wrote:
    You will like it
    I'm running about two weeks and works great
    two weeks? how many clients at a time? I have read a bit of their documentation and if I am not mistaken they recommend sizing the installation for about 12 clients per access point. That doesn't cut it for me, in a room I have to serve up to 50 clients. Also these are 2.4GHz only radios, what will happen when you have put 3 or 4 of them to follow their advice given that there are only 3 non overlapping channels and interference from Bluetooth, cordless phones (and neighbouring networks...)? I plan to satisfy the number of clients I have by using both bands, hoping iPads, iPhone 5 and Samsung smartphones and tablets will go to the 5GHz one on their own.
  • You probably need to email open mesh support. They will answer quite quick
    They do make dual band AP I use OM2P 26db version
    All channel are automatically done by the cloud
    So ask detail question to support
