wk55tw
Aug 02, 2013Novice
WNDR3400v1 won't connect to Internet after connecting HP B209 wirless printer
I have a WiFi network at home using Netgear WNDR3400v1 router. I have desktops, laptops, iPAD, & iPhone connected and work fine. But every time I turn on HP B209 wireless printer, anything connect to WiFi won't be able to connect to internet. All the wireless devices are still connected to WIFI and can see the printer. The desktops are able to connect to Internet in the mean time b/c they are Ethernet connected. To resolve the issue, I have to turn off the B209 and reset the WNDR3400v1. Does anyone have any idea what's the issue?
- Retired_MemberCheck to be sure your printer is not trying to make a direct connection is the only thing I can think of
- jmizoguchiVirtuosoThere is numerous thread on HP wifi printer causes the internet issues.
Search the forum. This is not netgear model specific.
Bunch of HP printer owner has post thread just like this - wk55twNoviceBy direct connection do you mean via USB? No, I can see the printer on the WIFI with IP -192.168.1.13 and I can send print job to it from my laptop. My issue is my WIFI connected deices can no longer access Internet except my desktops.
- wk55twNoviceWhen I 1st set up HP b209 wirless printer everything worked fine. I just started having Internet issue about 6 months ago. Not sure if this was caused by the firmware update I've done. But I'll check out the forum as you suggested.
- Retired_MemberI mean a direct wifi connection not a usb. I could wrong, but I thought some printers had the option to connect via wifi "AD HOC" and if your router changed channel with FW update it could now be a problem.
Just trying help!:confused: - jmizoguchiVirtuoso
wk55tw wrote: Not sure if this was caused by the firmware update I've done. But I'll check out the forum as you suggested.
If after firmware upgrade cause the issues then,
Make sure you have hard reset after you did.
I would even hard reset the router and test again. Is still the same then try to revert the firmware
Support.netgear.com and download prior firmware - wk55twNoviceAfter extensive search on the forum and few trial & error, I came to the conclusion the best way to resolve this issue is to restore my WNDR3400v1 firmware to version 1.0.0.38. I've tested the wireless printer and Internet connection after the downgrade and everything seem working. Hopefully this is it.
- jmizoguchiVirtuosoSometime firmware can breaks the feature it also fixes other bugs
Glad you figure it out
Enjoy
