jrfoleyjr
Oct 29, 2013Aspirant
WNDR3400v2 Wireless security question.
Does Netgear make a router or firmware that allows to kick a wireless user? :confused: If you have a pirate on your system regardless of having set the security, there should be a way to kick/ban...
ChrisP66
Jan 19, 2014Novice
First, I would recommend changing your password. Otherwise, on this router in the advanced setup>wps wizard> wireless setup, at the bottom there is a section to setup a "wireless card access list". That should let you whitelist the mac
addresses of your own equipment.
Good luck!
Good luck!
