pwil
Jul 01, 2013Aspirant
WNDR3700 and D-Link DRP-1260 Print Sever
After upgrading from a WGR614 router to the WNDR3700 my D-Link DPR-1260 USB PS does not connect via WIFI. I can use it with the network cable connected but it requires a reboot if not used for a few hours. I use the PS to connect to a Brother H1440 laser (USB only). Is there an incompatibility that I will have to live with or some other solution? I have rebooted everything and deleted and re-added the printer several times.
TIA
Phil
TIA
Phil
- jmizoguchiVirtuosoWNDR3700 is not WN3500rp.
Forum has specific place for your router
Belongs to http://forum1.netgear.com/forumdisplay.php?f=105
repost correct location - fordemMentorYou replaced the router - did you reconfigure the D-Link print server appropriately (ip address/SSID/encryption)?
- pwilAspirant
jmizoguchi wrote: WNDR3700 is not WN3500rp.
Thanks. I reposted there. - jmizoguchiVirtuoso
- ma447AspirantHey Guys, I have a D-Link 2730 Router and was thinking of purchasing the Netgear WN3000RP. Since they are different manufacturers, will they connect?
- jmizoguchiVirtuosoExtender joins existing network with exciting encryption such as WPA2
Should work
