Orchids
Jan 03, 2017Aspirant
WNDR4000 as an Access Point
Hi, I've setup my Netgear Router as a wireless Access Point & when I log in & look at connected devices, they all show up as Wired Devices & they are the same devices as my Router shows. Is this correct? I have the Netgear SSID set to the same as my Router & a static IP address. I can log into either one, but not sure I have it setup correctly?? Any ideas? Thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Orchids
It should be fine I think they show as wired because they are not connected to the routers wifi network and they are on the extenders.
DarrenM
