Thunder7's avatar
Thunder7
WNHDE111 disconnects/issues
Recently picked up the WNHDE111 kit and am having a few issues.
It hooked up fine, and found each other not problem. I have been able to access the internet with nice speeds from the far bridged end by being able to fully patch a new HTPC OS build through it. Did some testing of streaming some video and that worked fine too. I get an average rate of about 80%.
Now, the problem. I was trying to COPY some large files (multi-GB) from a wireless workstation on myh 11g network through the WNHDE111 kit to the far end workstation. It seems this higher than DSL speed activity causes the bridge WNHDE111 to lose its connection within 2-3 minutes (sometimes less). The device will have no lights on what-so-ever.
I have now set each device to their proper roll (i.e. AP and BRIGE hard coded instead of AUTO). I set static IP addresses for each.
Something strange I am noticing is on the AP when looking at the wireless status, it shows the IP of the bridge as one from my DHCP range (not the static address that has been assigned to it, and is used for management of the device). Why?
Any other suggestions for helping this device work under load? As it seems it isnt noise, but amount of traffic at LAN speed when copying files, as I have had no issues with normal internet speed activities.
  • Hey, refurbished versions of the WNHDE111 are flooding on ebay now, for the bargain price of £30. Unfortunately I suffered the same disconnections as mentioned a few years ago. It came with the original firmware, tried the update, then tried the beta, all suffer from a crash and reboot after transferring 500MB. I've tried every possible fix mentioned but those didn't solve it, however I think that by turning off WMM in the "Advanced Wireless" section it stops the crash, but at the expense of loss of 50% throughput. So by turning it off I go from about 8MB/s copying from a wired PC to 4MB/s. Btw I'm set to N only, channel 136, transmission auto (its connected at max because is right next to it), channel width 20/40, security none.
    If anyone else still has theirs perhaps they could try with WMM off too?
  • Hi, I'm selling two WNHDE111 devices on ebay atm -
    link at
    http://cgi.ebay.com.au/NETGEAR-WNHDEB111-HD-Gaming5-GHz-Wireless-N-2x-WNHDE111-/280627649417?pt=AU_Networking&hash=item4156b61b89
    I used two Netgear WNHDE111 devices as a temporary solution in getting internet access to our granny flat since the Ph lines and network cables had been severed!!! This got us back up and running again, however since the CAT5 cables have been relaid, we no longer require this Network Wireless Bridge solution. The can also be configured as normal Access Points also.
    cheers
  • I still have a pair of these units, and they are still dropping out....
    LOL
    Netgear, I will never buy another product from you ever.
    And I tell other people the like.
    I have this kit and a router from you which *also* suffers from a defect which plenty of other users have reported. (WGT624)
    Definitely shame on you.
  • Yeah...I threw mine in the trash. EXTREME disappointment with Netgear over these....
  • Agreed. I actually just tried all the firmwares, all the settings you can think of, trial and error, and nothing at all was able to get these to stay connected. It's a shame.
    I wouldn't be so mad, if it weren't for my other netgear router WGT624, completely from another era, that actually had a class action suite because it hangs or drops out when using the wireless! (dslreports.com/forum/remark,12918191)
    I seriously will never trust in Netgear again for anything.
