dozeone's avatar
dozeone
Follower
Jun 21, 2014
WNR3500Lv2 Telnet forwarding does not work
Hi all, I have been trying to set up port forwarding for a lazybone wifi device: http://www.tinyosshop.com/index.php?route=information/news&news_id=8 Connecting to it from Lan works, but trying to access it from the outside just gives: Trying 84.208.84.XXX... And nothing more happens, on the LAN i get: telnet 10.0.0.69 2000 Trying 10.0.0.69... Connected to 10.0.0.69. Escape character is '^]'. I have set up: Port Forwarding: DoorOpener outside port:6969 inside port: 2000 ip: 10.0.0.69
1 Reply
  • Do you really want the world to know what ip/port they can reach your door opener on? Especially given the fact that telnet sends it's credentials in "clear text".
    If you're using a static ip address on the opener, make sure you have a default gateway entry pointing back to the router.
