terry0729's avatar
terry0729
Follower
Nov 24, 2011
WPA2 Passphrase and Full key (WPN824v3)
Now that my wife has a relatively new device (iPAD), I decided to upgrade the home network from WEP to WPA2-PSK. The router accepts a passphrase and my two i-devices only require that to sync up. However I have Win7 laptop with internal wireless and also a mini-wireless adapter that I purchased this last summer. Neither of those devices will take the passphrase, requiring instead the full key, which is not displayed by the browser. I am at a loss. Is there some way to sync these devices? Thanking you in advance.
  • June, with all due respect, you keep pointing out problems yet you are not offering solutions.
    If the Netgear router uses passphrase's for all WPA encryption and Kindle will not accept a passphrase what are my choices other than a WEP setup?
    If kind only offer WEP then 2.4GHZ must WEP
    You change router to push other thans WEP when wifi device only supports WEP
    If you dual band router with guest account capable use kindle in guest account while test of better wifi device can use WPA2 on primary guest account
