bonzoWiltsUK's avatar
bonzoWiltsUK
Initiate
Dec 07, 2024
WPN802v2 browsers say connection not secure
WPN802v2
Windows 10
I cannot log in to the access point as the browser (e.g.) reports that (e.g. for Edge) :
The connection for this site is not secure
192.168.0.231 uses an unsupported protocol
ERR_SSL_OR_CIPHER_MISMATCH
Is there any workaround for this please, or do I have to bin this otherwise apparently perfectly working piece of kit?
I can make a wireless connection to the device appearing as 'NETGEAR' from my android phone.
  • Holy jezz, that thing is 19 years old. Its time to retire it and get something from this decade. Its on old b/g router with super slow speeds. Unless you're on 2-6mbps dialup/dsl, this thing is bottlenecking big time. Get ride of it.
  • plemans's avatar
    • bonzoWiltsUK's avatar
      bonzoWiltsUK
      Initiate
      Thank you plemans! I get the hint.
      I kind of feared the truth, always reluctant to add to the world's pile of junk.
      • plemans's avatar
        I'm not a fan of throwing things away either but since b/g, you've had wireless n, then AC, then AX, then AX 6ghz, and now BE, You're so far behind that if you have any decent speed at all, you'll see a massive performance boost with an upgrade.
