AurelWD's avatar
AurelWD
Follower
Jul 02, 2014
[WPN824EXT] Can't access to config webpage
Hi.
I have a wired connection between my computer and my router netgear on slot 1 and wired connection between my gateway and my router on the yellow slot. My 2 RJ45 are the same.
First, I have reseted my device to factory settings.
The router is working correctly however I can't access to config webpage through my internet browser using http://192.168.0.1 or http://192.168.1.1 or http://www.mywifiext.net/ or http://www.mywifiext.com/
Pathping to my gateway don't give my my router IP adress.
Help will be appreciated a lot, thank you.
