Wgs
Nov 14, 2016Aspirant
Wps light won't turn on
Just bought a EX6130. Manual says the WPS/Mode should be green. It isn't. Manual says to press the button 5 seconds. It blinks but then the light stays off. I reset the device, tried numerous times. M...
- Nov 16, 2016
Hello Wgs
Have you tried to setup the extender the manual way?
DarrenM
DarrenM
Nov 16, 2016Sr. NETGEAR Moderator
Hello Wgs
DarrenM
- WgsNov 22, 2016Aspirant
Many thanks. I ended up being able to get someone on phone support. It involved manual set up indeed but with tricks compared to the manual.
- Turpin1548Nov 24, 2016Aspirant
You couldn't possibly share the secret, could you?
Thanks
