Wgs
Nov 14, 2016Aspirant
Wps light won't turn on
Just bought a EX6130. Manual says the WPS/Mode should be green. It isn't. Manual says to press the button 5 seconds. It blinks but then the light stays off. I reset the device, tried numerous times. M...
- Nov 16, 2016
Hello Wgs
Have you tried to setup the extender the manual way?
DarrenM
DarrenM
Nov 16, 2016Sr. NETGEAR Moderator
Hello Wgs
DarrenM
Wgs
Nov 22, 2016Aspirant
Many thanks. I ended up being able to get someone on phone support. It involved manual set up indeed but with tricks compared to the manual.
- Turpin1548Nov 24, 2016Aspirant
You couldn't possibly share the secret, could you?
Thanks
