Wgs
Nov 14, 2016Aspirant
Wps light won't turn on
Just bought a EX6130. Manual says the WPS/Mode should be green. It isn't. Manual says to press the button 5 seconds. It blinks but then the light stays off. I reset the device, tried numerous times. M...
- Nov 16, 2016
Hello Wgs
Have you tried to setup the extender the manual way?
DarrenM
Wgs
Nov 24, 2016Aspirant
I would but there were too many steps I had to make while on the call so I'm afraid I would need to call again if I needed to start over. Sorry. But their phone support is definitely competent and helpful
- Turpin1548Nov 25, 2016Aspirant
Thanks for replying so promptly. The thing appears to be working properly now, and so I am rather loathe to touch it.
