Wgs
Nov 14, 2016Aspirant
Wps light won't turn on
Just bought a EX6130. Manual says the WPS/Mode should be green. It isn't. Manual says to press the button 5 seconds. It blinks but then the light stays off. I reset the device, tried numerous times. M...
- Nov 16, 2016
Hello Wgs
Have you tried to setup the extender the manual way?
DarrenM
Wgs
Nov 24, 2016Aspirant
I would but there were too many steps I had to make while on the call so I'm afraid I would need to call again if I needed to start over. Sorry. But their phone support is definitely competent and helpful
Turpin1548
Nov 25, 2016Aspirant
Thanks for replying so promptly. The thing appears to be working properly now, and so I am rather loathe to touch it.
