BretD's avatar
BretD
Administrator
Aug 29, 2017
X6S - The First Nighthawk® Tri-Band WiFi Range Extender EX8000
Nighthawk X6S Tri-band WiFi Range Extender EX8000Turn dead-zones into fun-zones.
Now you can easily build your own powerful extended WiFi network. Enjoy all the advanced router features that a Nighthawk has to offer and easily build your own powerful WiFi network by adding the Nighthawk X6S Tri-band WiFi Range Extender  Model EX8000 to your network. Now you have the flexibility to customize networks in 2.4 and 5GHz. Use your existing router's SSID to create a single network or use multiple SSIDs to create separate networks. With smart roaming and one WiFi name - we just revolutionized WiFI range extenders with the Nighthawk X6S. Learn more on the Nighthawk X6S Product Page.
8/29 - 9/1 - Ask Us Anything About the X6S WiFi Range Extender and Enter to Win one.
 Nighthawk X6S Range Extender Features:
  • Smart Roaming connects your mobile devices to the best available WiFi
  • Dedicated WiFi Link to router avoids cutting the extended WiFi bandwidth in half
  • MU-MIMO enables simultaneous streaming of data to multiple devices
  • Four Gigabit ports to connect wired devices like smart TVs and game consoles
Nighthawk X6S - EX8000 - Technical Specifications (Click for more)
  • 11ac
  • AC3000 up to 3Gbps
  • 4GHz/5GHz (5GHz Band 3)
  • 4x GB Ethernet ports
  • 1x USB 2.0
  • Power on/off button
PHYSICAL SPECIFICATIONS
  • Dimensions: 8.94 x 6.68 x 3.65 in (227 x 170 x 93 mm)
  • Weight: 1.9lb (0.86kg)
SYSTEM REQUIREMENTS
2.4 and/or 5GHz 802.11 a/b/g/n/ac WiFi router or gateway
Nighthawk X6S | EX8000 Press Release
Nighthawk Router not required but is recommended to be used with the Nighthawk X6S Tri-band Range Extender.
Where will you extend your Nighthawk Network with the Nighthawk X6S? Post a comment below. Also, discuss it in our dedicated Nighthawk Gaming Forum.
  • Hi, i want to buy this. I have already ex7300.
    This product can connect with "dedicated link" with my original router that is only 2.4 ghz?
    I need to create new home network, i not need same ssd id.
    Thanks.
  • I want to purchase the new EX8000, but wanted to know if I can have two of them connected to the same router for a big home.  I want to make sure they do seamless roaming  when I walk from end of the house to the other end.
  • I began using the X6S - The First Nighthawk® Tri-Band WiFi Range Extender EX8000, it seems to drop my wifi fairly regularly even when the signal is strong. Does anyone have any suggestions on how to correct this?
    • Raynsy's avatar
      Raynsy
      I share your plight. It droipped and reconnect itself within few seconds. Big problems when gaming.
  • I would like to pair 2 of these this with the R8000p Router.  However, I would like to use CAT6 wires to connect the Extenders to the Main Router.  The owners manual seems to suggest this can be done.  However, it does not describe whether I will still be able to use ONE SSID and have Smart Roaming.  Those appear to only apply when you use WIFI to connect the extenders.  I have thick concrete walls in my home and WIFI is not a solution, I need multiple access points to project WIFI coverage.
  • I am wondering the following about this product.
    1. Will this product work in AP mode if i hook it up to my cat6 network in my house instead of using the wireless link?
    2. Would i have to set it up with a different Network ID if i set it up this way instead of sharing the Network ID in the other configuration?
    • MotherFinMike's avatar
      MotherFinMike
      I had to return mine the connection was unstable & slow, My previous Ex7000 was more stable
      • Automan's avatar
        Automan
        Apprentice
        Logged a support call as I and at least one other cannot display the list of connected devices.
        A fairly basic feature I would have thought...
        Page just says please wait till it says your session has expired.
        Using my one in Access point mode and tried with chrome and edge browser.
        Please Wait
        Support call reference 29471317
    • Automan's avatar
      Automan
      Apprentice
      Yes it can be setup as an Access Point, just make sure it is plugged into an active network cable on first power up.
      You can set it to the same SSID as your existing 2.4 and 5.0 and give the third faster 5ghz SSID a new name.
      The "Do More" leaflet that ships with the unit gives the steps in detail.
      • AnthonyBe's avatar
        AnthonyBe
        Guide
        If you have the EX8000 in Access Point mode, and have One WiFi Name feature enabled, does the EX8000 and the router (in my case a D8500) do smart hand-off as you roam? Or can this only occur if you use the EX8000 in Extender mode? Sorry, the documentation is very confusing on clarifying these scenarios!
