ieatfishburrito
Sep 30, 2017Tutor
X6S Extender + X10 Router Issues
Hello, I recently replaced my prior wifi system with a new X10 router which is working well. I added an X6S to bring ethernet access to a few components at an enternaiment center. I'm in a 2500...
- Oct 08, 2017
I'd like to mark this as closed / solved thanks to support from Level 2 Jason.
1. The auto firmware update showed it was current, however there was a newer version posted for download on the website. We installed the updated firmware.
2. even at a distance of 2 meters from the X10 router, the 5G connection displayed as red in the extender page. We coulnd't find any interference with the channel, however we changed the 5G channel and everything came to life.
I've been running for 2 full days with the extender in it's permanent location with no hickups and spectacular performance. I'm seeing 118Mb connection at the extender ethernet ports, thrilled with perfomance.
Thanks again for the follow up and corrective actions.
DarrenM
Oct 02, 2017Sr. NETGEAR Moderator
Hello ieatfishburrito
Can you send me a PM with your name, email, and phone number I will have our support team contact and work with you directly.
DarrenM
ieatfishburrito
Oct 08, 2017Tutor
