ronsmith95
Mar 30, 2019Aspirant
X6S Tri-Band extender -why does signal strength bounce from -40 to -100?
When using indicated extender with U-verse Pace 5268AC Gateway, Wi-fI Explorer app shows my signal strength on 2.4 ghz bouncing back and forth between -40 or so and -100 or so every few seconds. Am u...
Mar 30, 2019Guru - Experienced User
What Firmware version is loaded on the EX?
What is the distance between the main host router and the EX unit?
What channels are you using on the main host router?
- ronsmith95Apr 05, 2019Aspirant
Thanks for reply. Been out of town. Answers to your questions:
Firmware 1.0.1.192
Approx 25 ft. from router
Channel 11 on 2.4 GHZ and 136 on 5 GHz
Netgear app shows my signal strength on 2.4 as 68% and 4 neighbors at 10% to 30%
Shows my signal strength on 5 as 70% and 1 other network at 14%
Closest neighbor lives over 100 ft. away.
Thanks.
- FURRYe38Apr 05, 2019Guru - Experienced User
Try 30 feet out with the EX. 20 feet is probably too close.
