ronsmith95
Mar 30, 2019Aspirant
X6S Tri-Band extender -why does signal strength bounce from -40 to -100?
When using indicated extender with U-verse Pace 5268AC Gateway, Wi-fI Explorer app shows my signal strength on 2.4 ghz bouncing back and forth between -40 or so and -100 or so every few seconds. Am u...
ronsmith95
Apr 05, 2019Aspirant
Thanks for reply. Been out of town. Answers to your questions:
Firmware 1.0.1.192
Approx 25 ft. from router
Channel 11 on 2.4 GHZ and 136 on 5 GHz
Netgear app shows my signal strength on 2.4 as 68% and 4 neighbors at 10% to 30%
Shows my signal strength on 5 as 70% and 1 other network at 14%
Closest neighbor lives over 100 ft. away.
Thanks.
Apr 05, 2019Guru - Experienced User
Try 30 feet out with the EX. 20 feet is probably too close.
