mwiederecht's avatar
mwiederecht
169.254.... address showing up in my Netgear Genie network map?
I've noticed that I get a device on one of my network maps from time to time.. with an IP address that starts with 169.254... does this mean someone is trying to login/hack my network? I was told that it's APIPA and I don't need to worry.
thx
  • Hi mwiederecht,
    1. What is the version of the Genie app that you have installed?
    2. Does the issue persist when viewing the Network Map on another device (iOS, Android, PC, another Mac)?
    3. Have you tried re-installing the Genie app?
    Dexter
    Community Team
  • this is now happening.. my Mac is showing up in the en0 map ( with a local IP - 192.168...) and on the en5 map .. but with a different IP address (169.254... )???
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi mwiederecht,
      1. The device is named as "Matts-iMac.home". Is that the name of your Mac computer?
      2. Judging by the screenshot, it looks like the Network Map is still loading. Does it display the same thing after it loads?
      3. Is your Mac computer connecting to the router via wireless or via Ethernet (wired)?
      4. Does that same device also show up on the attached devices page on the router UI?
      Dexter
      Community Team
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi mwiederecht,
        Dexter
        Community Team
