fivehundie's avatar
fivehundie
1750 R6400
Does the AC1750 R6400 router support DOCSIS 3.1?
  • The R series router is just a router only. No built in cable modem thus would not be any support for D3.1. However the R series router CAN connect to a separate cable modem that does have D3.1 support.
  • FURRYe38's avatar
    • fivehundie's avatar
      fivehundie
      Great! I didn't know if the router would accommodate a D3.1 modem but thanks to you, I now know. Thank you!
