ranjayQ's avatar
ranjayQ
Follower
Nov 29, 2019
192.168.1.1 won't work & not able to Login Netgear router
I don't know How but i amnot able to login netgear router. i have tried Routerlogin.com & .net Also 192.168.1.1 but no help. i amnot able to access netgear router admin page. what should i do ? i am using windows 10 to login netgear router
  • Hello ranjayQ
    Since you are using Windows 10 computer & as per my understanding You are not able to Login netgear router admin console for you to change the settings so this is How You Should go about this issue -
    • Restart your computer & refrsh the Browser (If Possible Try a different Browser ). make sure 192.168.1.1 is the default Ip Address & computer or Phone is connected to netgear router Before you access the setup page.
    • Go to 192.168.1.1 & access the Router Admin page using the default Login credentails. default Username is = admin , Password = password
    • Make sure You type the default Ip Address at the top of your Web address in (URL Box ) Once Logged in you are free to make changes as you wish.
    • if nothing works Please Reset the netgear router to start fresh & i am sure that Would Be Work Just Fine.
1 Reply
  • Hello ranjayQ
