Jsnipes's avatar
Jsnipes
3400v3 needs internet to allow set up
Ok, so I bought one of these today and tried to set it up for internet access but the place where it is going to be finally used is not where I am at. So I did not want it to default to my internet settings as they will be different when it gets there. As long as there was no internet access I could not get into the settings. Support told me that I needed to connect it directly to my modem in order for me to change the settings. But, alas, my ISP has provided me with a modem/router combination that cannot be separated. Has anyone found a way around this? It seems strange to sell a router that cannot be used as a router when there is no internet access. Who would have ever suspected that they would do this.
  • "The job is not done until the paperwork is done!"
    I was able to get into the set up by turning off the wireless on my computer and turning off the wireless on the router (there is a switch on the router to do this), then setting the ip address on the computer to 192.168.1.102 static (I did that to stay out of the dynamic range the router was using, it had been setting the computer's address to 192.168.1.2 and still not letting me into setup), Then both the computer and the router were restarted.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, Jsnipes
    The router admin page is accessible with or without Internet access.
    If you're connecting it through hardwired connection, make sure that you connect the computer to one of the 4 LAN ports at the back of the router.
    Once you have done that, the router should provide you an IP address of 192.168.1.x. You may see the link below for the steps on how access the admin page.
    How do I log in to my NETGEAR home router?
    If you cannot login to your router
    • Jsnipes's avatar
      Jsnipes
