Mark_McC
Apr 08, 2022Aspirant
5GHz question
My Samsung UE43TU7020KXXU TV can’t find / doesn’t recognise the 5GHz Wi-Fi band on a netgear D6220 Serial Number
michaelkenward
Apr 09, 2022Guru - Experienced User
Most Samsung devices I have cone across support only 2.4 GHz. That is perfectly fast enough to support just about any smart TV operation.
Connecting a TV to the network is usually best done through the TV's controls and set up routine. The router rarely does much more than spit out the wifi signal. It is then down to the TV to do its thing.
Where possible, it is usually easier to use a wired connection from the router to the TV. It is easier to set up and less likely to fall over. If you can't run Ethernet cables around the place, you could look into Powerline Ethernet. It turns your mains wiring into an Ethernet circuit.
