garyalan59's avatar
garyalan59
Follower
Jan 30, 2018
AC 1200 R6120 not accessible by my Amazon Fire TV
 Just replaced my Cisco wireless router with a NETGEAR AC 1200 Model R6120. Got the 6120 up and running for internet access, but the TV says the router is out of range and cannot be accessed. Current router is in exact same place as old router.
  • Hi garyalan59,
    1. What is the firmware version of the router?
    2. Are your other devices (smartphone, tablet, laptop) able to connect to the router at the distance where the Amazon Fire TV is located?
    3. Is the Amazon Fire TV able to detect other wireless networks?
    4. Have you tried changing the wireless channel?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi garyalan59,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi garyalan59,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
