mamabear311's avatar
mamabear311
Follower
Oct 28, 2017
AC 1200 R6220 Router Installation issues
I am trying to create an "open dns account" to open up parent controls. I got my username and password in there but when I click the Login button, it says "action failed, try again" I cant get past this, and tried to create another account but cant. what do I do? This process of hooking up this router has been taking wayyyyy too long and is not simple. Please help. Thanks
  • Hi mamabear311,
    1. What is the firmware version of the router?
    2. Have you tried going through the setup using another device (another computer, smartphone, tablet) via the Genie app?
    3. Have you tried resetting the router?
    4. Are you using an OpenDNS account that already exists?
    5. Please make sure you follow the steps linked below.
    http://kb.netgear.com/app/answers/detail/a_id/25687
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi mamabear311,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi mamabear311,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
