MikePeterson's avatar
MikePeterson
Ac1000 Router
When I try top connect the router, I'm told top enter the security code, I enter the WPA2 and it tells me that's incorrect and I 'm still not connected.
  • Connect to what?
    Enter security code where?
    Which router model? AC1000 is a speed, not model number.
    • michaelkenward's avatar
      michaelkenward
      The only AC1000 I can find in the system is the R6080, probably the bottom of the line for Netgear routers. I mean, 100 MBps LAN and WAN in 2017? Not something to use if the Internet is faster than 100 MBps.
      A good place to start looking for help is the manual.
      Visit the support pages:
      Support | NETGEAR
      Feed in the model number and check the documentation for that hardware.
